Home Forum Ask A Member What spark plug cross reference for Elgin
  • #184545
    seahuntboater
      Greetings. Is there a cross reference or does anybody know a champion or NGK, etc. equivalent to an Allstate A4-120 It is form 1954 7.5hp Elgin Model 571.58771 Serial 771.1772.
      Thanks
      Ralph
      #184550
        From the old Elgin site: ‘Over the years Sears recommended various Allstate, AC and Champion plugs for their motors. All of the 1946 – 1954 motors run well with modern Champion J11C plugs available at auto supply stores. The J11Cs come pre-gapped at 0.035″; this works fine for all the motors. The J11C is a little longer than the older spark plugs, and if your motor has a spark plug cover, care must be taken to make sure the spark does not jump to the cover’.
        I’m not sure about that 0.035″ gap as it seems a bit wide to me. Anyway, here’s a link taking you to all the known alternative plugs for the Champion J11C.
        https://www.sparkplug-crossreference.com/convert/CHAMP_PN/J11C
        • This reply was modified 6 years, 5 months ago by Mumbles.
        #184551
          My old info says that motor takes a Champion J-11-J.
          #184554
            Probably from when they mixed 30 W motor oil in with the gas. The C plug would be compatible with todays TCW III oil. Either way, it’s a nice hot plug.
            #184558
              Agreed, the old -J plugs have been discontinued and replaced with -C.
              #184563
              seahuntboater
                Thanks guys. I think I have some J11C’s up on the shelves.
                Ralph
