Home › Forum › Ask A Member › Wire gauge
- This topic has 15 replies, 11 voices, and was last updated 2 years, 2 months ago by
Bob Wight.
December 28, 2023 at 6:34 pm #283538
Rewiring the starter cable wire and do not know amp draw of starter. What gauge wire to use for the positive and negative also wire from battery to solenoid and solenoid to starter switch.
Jim Benjamin
December 28, 2023 at 10:16 pm #283542Typically the battery cables are 6ga and the switch wires are 16ga.
December 29, 2023 at 9:36 am #283545a jumper kit (6ga) for boosting cars may be cheaper and long enough if you need the 16 feet .. you can always add protection with heat shrink tubing over the wire pair.
December 30, 2023 at 11:05 am #283563Caution with the jumper cables, those and most are aluminum wire, not good for marine environment and can’t be soldered to terminal connectors. Suggest staying with copper.
December 30, 2023 at 12:48 pm #283567good point yet these wires are coated with copper should solder OK no?? or simply crimped
amp capacity should be ok for small OB starters and short distances
OP can compare cost/benefits or go copper if only a few feet are needed.
December 31, 2023 at 6:20 pm #283592Brillman wire company sells battery cable by the foot. there may be cheaper sources out there.
Home – The Brillman Company | Antique Tractor & Auto Electrical Parts
December 31, 2023 at 10:05 pm #283593good point yet these wires are coated with copper should solder OK no?? or simply crimped
Copper coated aluminum? Interesting. Don’t know that I’ve ever seen that. Would that be an electrolysis nightmare around salt water? Just wondering.
January 1, 2024 at 7:11 am #283602certainly possible..benj41 can choose ..if just freswater boating around here we just eat the stuff and melt ice with it 🙂
January 3, 2024 at 5:43 pm #283654Thank you all for your input and help. Now on my way to complete me starter wiring.
Benji
Jim Benjamin
January 3, 2024 at 8:49 pm #283657Frank,
I had the copper coated aluminum cables on my 79 Cadillac & the negative cable fried the air conditioning dash controls, VERY high resistance All GM’s more than likely to save weight for better gov fuel rating. (Junk!). Replaced with xhhw type wire & soldered my own terminals on. My 62 Chevy P.U. has the same for easy 30 years. Can be bought at electrical supply houses in any size. I chose xhhw for the best insulation. Mine was “rabbit” wire. Came from wire pulls that always ran away :)!
