Home Forum Ask A Member Wisconsin RBM exercise?
  • #174323
      First attempt to start this Wisconsin, or a RBM as far as that goes.
      This is the one that was missing the magneto, and I made a timer
      hooked up to battery ignition for it.
      I cranked on it for about 15 minutes before I got the camera out.
      Was already “wore out” by that time, lol.
      It made some smoke, fired a few times, and ripped the flywheel
      knob out of my had a couple of times.
      I played with the timing, fuel mixture, etc.
      Not sure what else to do, except brace up the transom
      on my test barrel !
      Found out the water pump works though…… it actually was pumping
      water while I was hand cranking!
      Any ideas?
      Thanks.
      https://youtu.be/cLPNsNn5S4o
        Buc – hard to say who got the most exercise, you or the motor! But the motor looks really great and I’m sure you’ll have it running in short order. Nice job on the restoration. Probably would help to beef up your barrel transom!
        #174336
          Thanks Bob. Not sure when I’ll be cranking on it again…..got a knot
          in my shoulder blade and can only turn my head one way now, lol.
          I made some braces this afternoon for the test barrel to “sturdy it up”.
            My shoulder was hurting just watching you spin it over!! At least nice to see you got enough of a break in the weather to get outside again.
            #174358
              • This reply was modified 5 years, 1 month ago by Tubs.
              #174359
                Tubs, thanks for your thoughts. Regarding fuel, I thought about maybe
                not enough, maybe too much. A couple of times I let the plug fire away
                a few seconds while the piston was at TDC, thinking it might get
                rid of excess fuel. I “think” my buzz coil is okay, but not 100% sure.
                It ran my Gray “hit and miss” a few years ago, lol.
                I hurt too much today to even lift the Wisconsin in the test barrel,
                and the stand it’s on isn’t adequate enough for test starting.
                I’ve been putting off going to the doctor to see what’s wrong
                with my shoulders, cuz I don’t want to know……. but
                may have to give in, as it’s affecting my “fun time”!
                dockbuster1
                    Dockbuster, thanks for sharing that video!
                    That one looks very similar to mine, except
                    mine was originally magneto. Not sure I could
                    put an original timer on mine or not. Probably
                    more rare than finding a magneto that would work.
                    Does yours start easy?
                    Hopefully before summer is over I’ll have a video of
                    mine running, lol.
                    Thanks!
                      Buzz Box that I was attempting to start the Wisconsin with.
                      May test it out soon on my Gray hit and miss engine to confirm
                      the set up works okay.
                      Ooops, I see the “add image” box vanished. 🙁
