Home › Forum › Ask A Member › Old and unusual screw sizes
- This topic has 12 replies, 7 voices, and was last updated 1 year, 1 month ago by joecb.
September 22, 2021 at 10:50 am #247056
Hello all. Following up on a discussion about old/ obsolete American Standard Screw sizes… I found my reference chart for sizes from #2 to #30 . This from an old fastener manufacturing company. When measuring the diameter of the thread, remember that the thread will be a few thousands smaller that the nominal body size.
Hope it will be useful and prevent problems from “almost alike” fasteners.
Joe B
September 22, 2021 at 11:28 am #247060That’s a handy chart and thanks for posting it!
And there are the #14 screws Johnson used on their rope sheaves which commonly get mistaken for being 1/4″.
What is the length the last column would be referring to?
September 22, 2021 at 11:33 am #247061The lengths in the last column, are the standard range of lengths that this company , The American Screw Company produced.
Joe B
September 22, 2021 at 10:24 pm #247095
Early Johnson had an odd shear pin Dia. as
well. I haven’t had any luck finding brass rod
that size.
September 24, 2021 at 10:52 pm #247164The screws used in the earlier Johnson rope sheaves are 10-30 screws. My South Bend lathe has no setting for cutting 30 threads per inch. My Cardiff does, but I don’t have the necessary headstock gear for it. I bought a 10-30 die from a place in Michigan for 11 dollars US. I use it to make new rope plate screws, and also made screws that work with my puller kit so I don’t have to hammer on the flywheel nut to get the flywheel off.
But here’s one for you. Check out the slotted hex-head bolts that are used to fasten the cylinder castings to the crankcase. They are 20 TPI but the major diameter measures at about 0.260″, whereas most 1/4″ fasteners measure a few thou under 0.250″. Using a regular 1/4-20 fastener is not recommended for that particular application.
Hope it helps, but it’s somebody else’s fault if it doesn’t
Best,
PM T21 user thanked author for this post.
September 25, 2021 at 6:03 pm #247236Dear Prime Minister … 0.260 (that be 6.604 mm for some of you guys) is likely the #16 -20 from the chart, body diameter of 0.268
Joe B
September 25, 2021 at 9:00 pm #247245
This is the little bugger. Luckily they don’t
get the attention that the flywheel screws do
so they are, normally, still in good condition.
September 29, 2021 at 8:31 pm #247486I ran across an odd size thread today, on the 1925 Elto Lightwin, model C,
on the water outlet tube that goes thru the exhaust manifold.
I had no tap or die for this one.The thread OD measured .388, and it has 27 TPI.
I didn’t even know my thread gauge has 27 tpi, let
alone hear of that thread.Prepare to be boarded!
September 29, 2021 at 9:27 pm #247497One encounters 27 tpi on some pipe fittings, with out going down to the shop to measure, I’ll bet that that is a 1/8 NPS ( National Pipe Straight) as opposed to the common 1/8 NPT ( Tapered) , both are 27 TPI. I think that if you go to a lamp supply store , you will discover that the common threaded tube in most light fixtures is 1/8 (27 tpi) NPS
AND yet another caution… careful that there is a British 1/8 pipe that is 28 TPI
All this is great fun , and we haven’t even gotten into the metric and Whitworth stuff yet.
Joe B
September 29, 2021 at 10:18 pm #247500Joe, I should have thought about the pipe thread possibility!
The specs I found are pretty close to what I have…….Nominal Pipe Size (inch) – 1/8″ NPT
No. Of Threads Per Inch – 27
Outside Dia. (inch) – 0.405Prepare to be boarded!
