Home Forum Ask A Member Caille Neptune Gas Tank Repair?
Viewing 10 posts - 11 through 20 (of 95 total)
  • #223868
      Bob, solder everywhere! The rivets were soldered and peened,
      and thin tin washer inside the tank on the rivets that hold the
      mounting casting.
      Amazing it lasted 100 years in as good
      a shape as it was.
        Well, the tank may have rusted out but the casting sure weren’t going anywhere!
        1982 Evinrude 25hp
        #223901
        JOSEPH BRINCAT
          OK, I’m back and will try and answer the questions that Buccaneer asked about how I did my tank.
          – sheet metal? The common material for fuel tanks was Terrne, that is lead coated steel. Hard to find these days, but I was fortunate to find a few pieces 024 thick, that is what I used for the top and bottom panels. Used much thinner stock, 014 bright (tin) steel for the sides as the thinner stock allowed for easier forming of the required tight “S” bend.
          – solder ? I used regular 50/50 lead solder and NoKrode paste flux. If one used galvanized (zinc coated) steel you may need more aggressive acid flux
          – soldering tool? A heavy duty electric soldering copper ( not the little gun type for electrical work)
          – Forming ? Used matching hardwood ( maple) forms for top and bottom panels to form the 3/16 wide flange. To hand form the “S” shape on the side panel , clamped the stock strip between steel bar and carefully mallet formed the “S” in stages.
          – Rivets? soft brass rivets, penned and soldered inside and out.
          Assembly? First join the bottom to the sides, next the brass pieces riveted and soldered to the bottom. Finally close the top.
          Hope this helps,
          #223903
            Joe, much appreciate your posting this information, and enjoyed talking with you!
            I have a lot of good tips to get me started now.
            Thanks!
              #223914
                Tubs, Hopefully I don’t end up with a one gallon gas can strapped
                atop the motor with plumber’s strap!
                  Solder and Flux is on order. I dug around a found some sheet metal…
                  either for practice, or finished tank…. depending what happens. I found
                  some .028 thick for the top and bottom, and some .019 thick for the
                  side band, which has the double bent lip to accept the top and bottom
                  tank pieces.
                  Joe B. suggested making a pattern (two identical) the shape of the tank bottom and top
                  out of maple, then sandwich the tin, clamped between the two patterns for forming the lips.
                  The lumber yard is fresh out of maple, but I found a piece of
                  3/4″ plywood…. again, good enough for practice.
                  So far I only have the bottom piece cut out and the lip formed around the
                  3/4″ plywood.
                  It seems I need 9/64″ diameter rivets. The original were steel, but I’d prefer
                  brass. They seem to be hard to find online, but by chance, I’ll look
                  through my dad’s old cache of rivets in a 5 gallon bucket just in case.
                  More fun tomorrow.
                  DSCN9864
                  DSCN9866
                  DSCN9870
                  DSCN9873
                    just another thought. save the wood and make a tank out of it and fiberglass it.
                    • This reply was modified 5 years, 8 months ago by DAVID.
                    #224002
                      Buc – that bottom panel looks like a mighty good “practice” piece to me! Very nice work! Keep posting progress pics.
                      Edit – haven’t looked them up in a long time, but there used to be a place called Blacksmith Bolts that used to have a large variety of specialty bolts and rivets. Might try them for your brass rivets.
                      1982 Evinrude 25hp
                      • This reply was modified 5 years, 8 months ago by Bob Wight.
                      #224017
                      JOSEPH BRINCAT
                        Buc, Looking real good so far . I can’t tell from the pix, is that sheet metal galvanized? If so, looks to be dirty and/or oxidized (dark color) , be sure to clean to bright condition before attempting to solder.
