Home › Forum › Ask A Member › Evinrude 4305 Coil
- This topic has 20 replies, 5 voices, and was last updated 6 years, 9 months ago by garry-in-michigan.
July 18, 2017 at 7:28 pm #61828
Yes, the knot is kind of a challenge. What I have done is drilled a hole for a small roll pin near the hole the hook went into to help hold the knot. If that isn’t done the hole has a nasty habit of cutting the knot off the end of the rope. After tying the knot, I heat the knot with lighter and kind of mash it flat with a flat blade screwdriver to keep it out of the way. This has worked for me so far without issue.
-BenOldJohnnyRude on YouTube
July 18, 2017 at 8:33 pm #61835Works for me . . . 😀
July 19, 2017 at 1:35 pm #61861Looks like I’ve got a couple more questions- What should the plug gap be? I set it very roughly at first to make sure it ran. And is there any good replacement for the cork float? I coated it in 3 coats of the fuel proof model airplane dope but it still sunk after a little while
July 19, 2017 at 6:45 pm #61879Your 1939 Sportwin has a bore of 1.75" and a stroke of 1.375" for a piston displacement of 6.6 cubic inches. It develops 3.3 horse power @ 3,500 RPM. The fuel tank holds 6.5 pints, the oil to gas mix is 1/3 of a pint to the gallon (1 to 24 ratio) The 132584 shear pin is a3/16" diameter number 3 shear Aluminum rod 15/16" long. The two bladed aluminum semi-weedless propeller has a diameter of 7.5" and pitch of 6". The gears are lubricated by Grease as he cork seals are not the best, but better than nothing. Hope this helps . . . 😀
You will note that the 121020 feeler gauge in the tool kit shown o page 4 has a spark plug end of 0.025" & breaker point end of 0.020"
Starting and operating instructions
The factory specified Champion H10J spark plug has been replaced by there CJ8 – check website for latest numbers
The float may be replaced by modifying Mercury 1395-8983 (NAPA 18-7308)
Carburetor specifications –
July 19, 2017 at 8:46 pm #61883Thanks! I’ll definitely save all those pictures for future reference! Looks like a previous owner put in a couple J7J’s instead of the CJ8’s, is there any meaningful difference, or can I get away with the J7J’s?
July 20, 2017 at 9:51 pm #61934The J7 is good. It should run with a tan color. The coil high voltage secondary has a spark plug wire on each end. To complete the circuit both plugs must be grounded. If one plug gets fouled out the other has the potential to see an increase in voltage. However the voltage will be only what is required to overcome the resistance of the circuit. (up to the maximum that the magneto is capable of, at which point it fails) So if you ground one plug wire, the other should be able to jump a 1/2" gap to ground at fast cranking speed. . . 😯
July 21, 2017 at 1:03 am #61943Perfect, I’ll make sure they’re nice and clean before I run it next
July 21, 2017 at 2:58 pm #61971AnonymousIs 3/8" diameter too big?
July 21, 2017 at 4:38 pm #61975
Three eights inch diameter of what ? . . . ❓July 22, 2017 at 7:03 am #62016AnonymousSorry Garry, should have used quotes. The OP found some starter rope with wire core which was 3/8" dia.
Kirk -
