Home Forum Ask A Member Flywheel persuasion
  • #46868
      I have had success removing the hub by using a thin cut off wheel and cutting the slot over the key. Removing a coil gives you more room. The top is easy. Be careful near the bottom. I have a flexible shaft on my dremel and that helps me get close. Slow and careful does the job. Just a little out of line will break the wheel. After you are down as far as possible, drive a wedge into the top of the slot and add a few drops of penetrating oil. It should pop right off with a little prying. . . 😀
      #46894
      olcah
        From Frank’s table It looks to me like the flywheels should interchange. I notice that the original 1956 Johnson flywheel seems to sit on the taper about 1/8 lower than the flywheel from the 1954 motor. I’ll check more when I reassemble.
        #46895
        olcah
          Garry, I will print your procedure off and save it. If all else fails that would be a way out. Grinding at the keyway is a great idea. Thank you.
          #46896
          fleetwin
            US Member - 2 Years
            Don’t know if the 54 flywheel will actually fit, but it is physically different than what you have…You should be able to find the proper flywheel without much trouble or expense…
            Sometimes a 1/2" impact gun helps pop those flywheels as well…
