quote 1946Zephyr:
If that is a split case lower, I have all the innards, if you need them.
This is not a split case like more modern QD’s. The prop shaft, gears, etc. come out from the rear.
David,
I am pretty sure those gears are the same. You should be able to tell by some measurements on each. I don’t think the clutch dog on that motor can be flipped, but the gears could be swapped around if they appear to be the same.
I think the split case started in 1951 with the QD-12 which is a different critter altogether.
