Home › Forum › Ask A Member › Johnson S-45 Impeller
  • #232957
    What kind of impeller does this motor use?
    #232958
    Tom
      The S-45 doesn’t have an impeller. Water is forced up to the powerhead by a scoop in back of the prop, and the return is pulled out at a port in front of the prop. The water tubes need to be sealed for this system to work.
      T
      #232959
      Thanks
      I thought it might be something like that. I bought it as part of a 3 motor deal 10-12 years ago and It has been sitting on the rack since. Recently started to weed things out and see what would run and what was going to be parts. Turns out this one is a runner.
      #233074
      Tom
        My S-45 is one of the few larger motors I regret letting go; it was a lot of fun to run. But it was very difficult to move around alone without losing fingers. I hope you enjoy yours!
        T
        #233161
        Near as I can tell it is complete except for the cover over the carb intake. I wanted to restore it but the time just isn’t there so it is one that will have to go.
        #233163
        sydinnj
          Late 20’s early 30’s open flywheel. My favorite motors. Where are you located
          #233248
          Jamesville, NY
