Home › Forum › Ask A Member › OMC starter replacements 1957 35 HP
- This topic has 6 replies, 5 voices, and was last updated 4 years, 11 months ago by
outboardnut.
September 22, 2021 at 6:28 pm #247077
Just looking for confirmation on a replacement starter from someone who has done it. I have a 1957 35 HP Johnson RDE-19M. It has the Autolite MD04002M starter. I have other motors I could take one from and I am aware they can be rebuilt. The motor is at my weekend place and I have not disassembled it for inspection.
With that said is the Arco 5376 a direct bolt on replacement?
Has anyone installed a new brush holder like this one for sale on Ebay on this actual starter?https://www.ebay.com/itm/294396799436?hash=item448b6aa9cc:g:p8MAAOSwdyphQRF1
Thanks in advance for all responses.
MikeSeptember 22, 2021 at 6:31 pm #247078That brush holder won’t work on your 1957 starter.
September 22, 2021 at 8:36 pm #247089I tried rebuilding an old dead starter for my ’57 35HP javelin. I gave up and took a chance on one of these $60 no-name eBay starters. https://www.ebay.com/itm/143551363592 I figured it was worth a try.
All I can say is that a.) it bolted right in, b.) it fired right up and c.) 3 years & a ton of starts later, it’s still going strong.
September 23, 2021 at 12:45 pm #247106Thanks nj-boatbuilder57.
Was the positive cable connection in the same location, plenty of clearance? Looking at the pictures the new starters appear to have the connector midway between the mounting bolts. I don’t think the original starter is that way.September 23, 2021 at 1:13 pm #247107My engine was a complete rebuild…mechanically & electrically…with all-new wiring. I measured out new cables and cut / terminated as needed, so I had no issues. Will a pre-existing OMC harness work? I’m afraid I don’t know / can’t say.
What I CAN say, however, is that the (+) terminal didn’t mechanically interfere with anything else under the hood. No danger of shorting out…at least on my engine, anyway.
This reply was modified 4 years, 11 months ago by
nj-boatbuilder57.
September 23, 2021 at 1:49 pm #247109I ran an EBay starter on my 30HP 1956 Johnson all summer (about 50 gal used). It worked fine although I needed a starter bracket for a 12V starter to mount it.
September 23, 2021 at 4:02 pm #247117This is what I was planning on buying for
1955 RDE-17 25 Johnson
Yep I have 12 volt bracket
https://www.dbelectrical.com/products/starter-for-evinrude-outboard-e25e-e25el-e25te-e25tel-1966-1998-sab0109.html1 user thanked author for this post.
