Home Forum Ask A Member Silicone to replace power head base gasket?
  • #41160
    amuller
      Just our of curiosity, collectorinspector, why don’t you like RTV? Seems to me that if the name of the game is to be able to remove the powerhead without needing a new gasket each time, RTV on one surface might be good, as it seals but is not a very strong adhesive….
      #41162
      amuller
        quote pugetsoundboater:
        You do not want to use anti sieze with copper on Aluminum in it due to the galvanic corrosion/dissimilar metals issue. I use Jet Lube Marine Grade Non Metallic Anti sieze.Fastenal stocks it. Locktite makes one also.
        Thanks. The local Fastenall did not seem to have it, so I ordered some from Amazon.
