Home › Forum › Ask A Member › 1927 Johnson AB-25
Viewing 10 posts - 1 through 10 (of 24 total)
  • #315195
    David Bartlett
      As the title says, I am also working on a Johnson AB-25, the salt water version of the  A-25. I have the magneto off for spark plug wire replacement, so decided to clean the carb and generally look it over as it is new to me.
      I discovered that it does have spark(gotta love those Johnson coils), and was putting the plugs back when I noticed this!
      IMG_6919
      Pistons were upside down, so removed cylinders and put the moving parts in their proper location on the crankshaft.
      David Bartlett
      #315208
        The last guy had a 50 / 50 chance of getting those pistons correct
        and he blew it, lol.
        I still have one motor on the rack from years ago that I wonder
        if the pistons are in correct. It ran bad!
          Did they get the connecting rods on the correct sides?
          #315217
          PM T2
            Is your motor a 1926 by chance? 1927 would have seen the arrival of the A-35. I don’t know if that one came in a bronze version.
            Re the backwards/upside down pistons, have seen it numerous times. I suppose its easy to forget which way the pistons ought to be installed if the assembler flips the crankshaft upside down and looses track of which end is up.
            This is a Johnson BN that had the same problem
            BN-pistons-incorrect-1
            The next day it took me out on the lake. I think they are extra grateful after you fix them.
            IMG_4665
            PM T2
            #315244
            DAVID KELLEY
              I like your tiller tamer on that BN.  : )
              #315248
              David Bartlett
                Tubs,
                The rods were ok.
                David Bartlett
                #315249
                David Bartlett
                  Chris,
                  According to the serial number it is a 1927 model.
                  David Bartlett
                  #315271
                    Not Mine. From my picture files.
                    #315303
                    David Bartlett
                      Tubs,
                      This is from my motor. Pretty close in number.IMG_6921
                      David Bartlett
                      #315352
