Home Forum Ask A Member 1959 fisherman 5.5 help
Viewing 8 posts - 61 through 68 (of 68 total)
  • #176751
      172522 is correct
      #176758
      cookjer24
        ok thanks..when i get new points put in top cylinder side i will post results maybe the set i put in is bad or faulty for some reason..hopfully it brings it back to how it use to be
        #177160
        cookjer24
          UPDATE…so i beat the gremlin lol i am now sitting here as i type this update drinking some cold summer shanty with great news i got it sparking and hopefully it is fixed for long time..so the problem was the points gap..for some odd reason it is set at 12 thousands instead of 20 and i got great spark..set it to 20 where it should be and nothing very wierd but it is working and i cant complain becouse i got my little sweet running vintage motor back to go kill the panfish on the lake…thanks every one for info and what to check….dont think anyone would have guessed to make the gap smaller to see if it sparks.case closed for now lol.
          #177162
            Good to hear you finally tracked it down. Enjoy the motor, enjoy the fishing and enjoy the shanty!
            #177174
            cookjer24
              si i been thinking this morning…wounder if the points are not as thick as factory and that why i have to set it half the gap that it should be
              #177175
              cookjer24
                and thanks i will enjoy it…i always do..this is the first problem i had with it since i bought the motor 4 years ago…other than this it been a great little motor
                #177182
                cookjer24
                  well the rain stoped long enough to tank test the motor…still have a gremlin at half throttle from idle to half it is fine half to 3/4 it cuts out yet and 3/4 to full it is fine…i’m thinking it is the mag plate itself…there is a little bit of wobble play in it so can you put a new bushing in the mag plate or do you have to try and find one in better shape or is there a fix for this..at least i can still use it and get out on the water.
                  #177297
                    rub arms on points have different lengths… make certain you are using the proper point size for your engine
