Home Forum Ask A Member Armature Plate Lubrication
  • #246879
    Carlasdaddy
      What should I use to lubricate between the armature plate and it’s retaining ring? I’m thinking maybe wheel bearing grease would be a good choice.
      #246915
      need2fish
        Wheel bearing grease is far too viscous – especially at low temperatures. Consider a low temperature lithium grease.
        Ensure all surfaces are clean, dry and especially have no grit on them.
        Apply thin coats to:
        o the inner surface of the crankshaft hole,
        o the underside of the mag plate where it rides on the armature support plate, and
        o the top of the retainer ring.
        While you are in there, give each points cam follower pad a drop of light machine oil.
        #246920
          The OMC moly lube…
          This is a very tricky technique for sure. “just enough”…. Too much, and lube will get into the mag plate/points, and not enough will cause wear the the pilot bushing/mag plate and retainer ring…
