Home Forum Ask A Member Bad coil
  • #206156
    tinkerman
      So if mine is not a wico, then what type is it? Pfelon? Are there any replacements? Alternatives? Could you use a same type coil for a twin cylinder? Jump one plug wire to the other at the coil or just cut the 2nd wire at the coil? I have this champion and a handitwin that are really nice and a couple of not so nice engines I could try swapping coils but they are twin cylinders
      It's a jungle out there.
      #206249
      tinkerman
        Well I did some research and bought a good multimeter (well $20 if that’s good lol) with a needle. Checked the coil on the little champion , and it said it was good. I went over everything one more time an found some bad insulation on the kill switch wire. I rewired everything and checked the condenser (which was good) put it all back together and put gas in and tried to start. About the 4th pull she fired up! Now I need to see if I can figure out what the carb settings should be. It’s got two levers and a knob at the bottom of the float bowl. It sneezed a time or two, I may need to clean it good. Even with my research I still don’t know which type of coil I’m dealing with. It’s the dark brown round one. Anyway maybe someone with similar problems can read this and know not to just write the coil off just because their not getting fire
        #206255
        JOHN D.
          That looks like an Americn Bosch magneto. Several other brands use this same magneto. Any coil you can fit in there without rubbing problems with the flywheel will work. You may have to grind down the laminations to fit the new coil. By the way, great you got it running.
