Home Forum Ask A Member British Seagull CD ign. high tension lead replacement
  • #294526
    GUY SCHMIDT
      Help, I have a Seagull that needs a new spark plug wire. It has a recoil starter and electronic ignition. Not sure how to take it apart.
      There are 4 rivet fasteners on top. There are 2 what look like set screws below the rivets and 4 bolts at the bottom facing up.
      Which ones should be removed to gain access to the high tension lead?
      #294551
      Michael Anfossi
        International Member
        Remove the 4 facing up and the 2/3 set screws. Not sure with CD ignition you have, but if I remember correctly the brown/blacks the lead is not removable. The white one with twist out but the sparkplug lead is a much smaller gauge than the more usual 7mm stuff.
        removing the flywheel is done without a puller as per factory instructions.
        #294713
        GUY SCHMIDT
          Thank you !
