Home Forum Ask A Member Caille Neptune Gas Tank Repair?
Viewing 10 posts - 21 through 30 (of 95 total)
  • #224040
      Joe, the sheet metal is not galvanized. It has a little flash rust on it, and I scrubbed
      it with phosphoric acid and wiped it down with some WD40.
      Thanks for the reminder to clean it shiny before soldering.
      If I end up using these practice pieces for a tank, I was toying with the idea
      of putting gas tank sealer in it when I’m done. Pretty sure this plain
      sheet metal won’t hold together 100 years like the original Terne stuff.
        Today I made the top gas tank panel, so that means I just have the side bands
        to do. I’m afraid the top and bottom panels were the “easy” part.
        I cut a piece of metal for the small side panel. There must be an easier
        way to fold over the “S” lips on the side panel that the top and bottom fit
        into. Evidently the Caille factory figured it out over 100 years ago.
        I have a sheet metal hand folder which is ill suited for these short bends.
        Not sure how it would even be done if one had a sheet metal brake.
        I did one side of a little scrap first, and even that was somewhat of a pain.
        The short side panel is 15″ long, and the one side side I formed with
        a lot of manual manipulation was a “big” pain.
        Any idea what magic tool they used at the factory for these short folds?
        Thanks.
        DSCN9874
        DSCN9875
        DSCN9877
        DSCN9878
        • This reply was modified 5 years, 3 months ago by Buccaneer.
        #224081
        JOSEPH BRINCAT
          That “S” bend is looking pretty good. When I did my back panel, which had to be 28 ” long, I used a matched pair of 1/2 X 1- 1/2″ cold rolled steel bars 30″ long to sandwich the sheet metal strip. The bars were drilled and bolted at each end to keep them matched. Insert the sheet metal , clamp in vice and add a couple of C clamps to ensure nothing moves. Cold rolled steel bar is best because it has sharp square edges for making the bend. Form the “S” step by step… one flange at a time. Inner bend first, then the back side of the 180*. Flatten the 180 *, last using a spacer strip to control the gap, close the “S”. Now turn the strip over and do the same on the other edge. Note that your steel bars have to be narrow enough to fit between the two “S” edges. Hope that this makes sense.
          #224082
            Joe, thanks for the help. Just going to bed, and too tired to think now,
            but I think I get the idea. Will see what I might have around to
            make a fixture like you suggest!
            Thanks.
            RICHARD A. WHITE
              I think that is called a “Pittsburgh” seam????
              classicomctools@gmail.com
              #224085
                Richard, from watching YouTube, Pittsburgh seams are very similar,
                other than the overlap of the folds.
                  I finished the smallest side panel today, and started on the long, 28″ one.
                  The original small side panel simply had 90 degree folded edges
                  that went over the top and bottom panels and were soldered.
                  The longer side panel has the Pittsburg style crimps that the top
                  and bottom panels “set into”.
                  It was one of these simple folded seams on the original small
                  panel that was “popped open” when I got it.
                  Joe B. mentioned that he did both panels with the Pittsburg style
                  joints.
                  I’m not sure how to best join the small and long end panels together
                  at their two end joints.
                  Joe, did you join the side panels with any kind of locking joint,
                  or overlapping 90 degree flanges, or ??
                  Thanks!
                  DSCN9881
                  DSCN9883
                  DSCN9887
                  DSCN9889
                  JOSEPH BRINCAT
                    Buc, that job is coming right along…. looking read nice. Joints for the ends of the side panels…. I formed the same “S” on the ends of the long panel and just a 90* flange on the ends of the short panel to fit into the “S”.
                    Noe your job is coming along so well that you deserve a reward. Did you find any bras rivets yet? if not, I have a few left that I’ll send.
                    #224148
                      Buc – that kind of work is way beyond my skill set but it sure looks like it’s going to turn out really nice! Can’t wait to see the finished project!
                      #224154
                        Thanks Joe! That should make for a stronger joint than it was before.
                        It would be a fun project “if” I had the proper tools, like a sheet
                        metal brake. I’d like to spend a day in the Caille factory watching
                        them make those tanks!
                        I found some rivets, but none perfect. Some are steel, some may
                        be too long, or too short. I think there were some brass ones
                        the right size, but they have the hollow end, not sure about
                        the length. I need to make a specialty punch for peening
                        the hollow ended rivets, and do a little practicing on some scrap
                        before I know if any of my rivets will work.
                        Thanks!
