Home › Forum › Ask A Member › Cannot identify this rude !
  • #2602
    omcbeaulieu86
      😕 For some reason this doesn’t seem to fit the code. It’s a 35hp evinrude probably early nineties with code ce20crcdc. I think the twenty is suppose to mean twenty horse but the vowel says 35 and it looks just like my buddy’s 35 he has. (His transom bracket is wider though)
      Any ideas ?
      #24365
      omcbeaulieu86
        Oops. I meant to say early 80s
        #24367
          OK, this is how I break down your serial number but it might not be right.
          CE 20CRCDC
          CE = Canada Evinrude
          20 = 20 Horse Power
          CR = Canada Derated, Rope Start
          CD = 1986
          C = Model Run Suffix
          So what you have is a Canadian built short shaft twenty horse Evinrude with a 35 horse cover or hood on it.
          #24373
          omcbeaulieu86
            Is it possible that the lower unit and gear case can be from a twenty but the power head a 35? I’ll get the number on the power head to confirm.
            #24377
            chinewalker
              The 20-35 all used the same basic configuration. The 20 used a lighter duty clamp assembly. Also had s smaller bore carb and a restricted intake manifold.
