Home Forum Ask A Member Carl is about to light up another cigar in his coffin….
  • This topic has 21 replies, 15 voices, and was last updated 5 years ago by billw.
  • #230249
    rudderless
      I have read it comes in a 20″ version. Maybe for a bass boat?? 🙂
      #230273
        If the first 6 cylinder in-line 100hp Merc was called the Tower of Power, what do you call this thing?
        #230280
          I’m with Carl… what the hey is “Contra” rotating.????!!!!… no credibility with me.
          Each engine has two props, that turn in opposite directions. It makes for a tremendous bite on the water. I have always called them counter-rotating. Volvo has had this on their outdrives back into at least the 1990’s and I think they got the idea from torpedoes. I am not sure you guys caught this, but the whole engine doesn’t turn to steer; just the lower unit, which will turn further than a whole engine would turn. Some of our antiques did that, didn’t they?
          #230303
            TWIN TOWER OF POWER !
            #230324
            ROBERT LAFAYETTE
              EXPENSIVE!
              Only $77,000 each plus boat & trailer!
              https://www.tcpalm.com/story/sports/fishing-boating/2021/02/11/mercury-marine-unveils-innovative-new-outboard-engine-v-12-600-hp-verado-has-steerable-gearcase/4410659001/
              Scan06
              #230329
                Surely looks impressive, sure hope they tested the heck out of em…. There is no test that can quite match consumer testing unfortunately…
                #230376
                rudderless
                  …I think ya mean consumer abuse! 😉
                  #230388
                    I was thinking exactly the same thing. A point well taken, from a former OMC guy!
                    #230390
                      Yeah, if OMC couldn’t make it, then I hope Merc does….
                      #231191
                      Evinrude 25
                        It is a dual Tower of Power! Two Tower of Power joins together at the hip.
                        How fast do you estimate if put it on my 18′ aluminum boat? Should I order the short shaft version? If it is not available, should the standard shaft version be fine with and a jack plate installed?
