Home Forum Ask A Member Cowl trim Merc 7.5hp
  • #286483
      As replacement to more expensive  Merc trims ………..I ordered   some   Amazon car door trim as a test.  Previous trim  I got  was a bit slim  (narrow) so I got this one  .
      turns out it fits nicely and grips the trim very well.  No need for   GOOP glue  but  it would not hurt I guess.  The cowls  rides nicely
      see pictures.  some molded  rround  reenforcements on theedge   will require a small snip in the trim to fit (not a real problem)
      the new trim extends beyond the cowl edge my maybe  3/32 inch  and  is not apparent really… being black
      I’ll fininsh up the job  in a few days and repost  some pics.
      #286487
      labrador-guy
        crosbyman that will work!   It is the same stuff that is on a helmet.  It goes around the lower edge of the fiberglass shell.  It makes a good seal and rattle prevent er.
        dale
        #286537
          UPDATE:
          well … not a 100% job but it won’t  rattle!
          The rear of the cowl was to tight the trim would not allow closure but…85% of the side  was trimmed with the edging and  the cowl fits rock solid.
          I would have like 100% fit but 85% will do compared to nothing for my occasionnal trips.   at least some fresh air will enter under the cowling 🙂
          note: edging looks wide  but  the cowl’s edge comes way down to cover it …nobody would notice it sticking out
