Home Forum Ask A Member Does it even matter ?
  • #39799
    RICHARD A. WHITE
      quote 1946Zephyr:
      I can imagine drilling into that pin might be tough. Those are tool steel, aren’t they? If you are lucky enough to dril into it, it should come out fairly easy with an extractor…..unless someone locktited it.
      Nope, mild steel, I made a jig for my buddy Scott Parrish to replace them in a 35 or 40 hp motor he was working on. OMC has a tool for that, mine is quite similar. Pins are available and pretty cheap.
      classicomctools@gmail.com
      #39812
      Leon
        Cool deal. Never had to drill one yet, but now I know 🙂
        #39830
        wedgie
          Thanks everyone 😀 . I drilled it, and of course the hole is a little bit bigger than original now, but it shouldn’t be a problem if I put a dab of marine tex in the hole before I drop the new pin in there. For the pin, I just grabbed an old drill bit that’s close in size and cut a piece off of it.
