Home › Forum › Ask A Member › Elto Cub coil/magneto substitute question
- This topic has 15 replies, 8 voices, and was last updated 8 years, 5 months ago by
bob-d.
October 3, 2017 at 4:20 am #8382
Currently rebuilding a barn find Elto Cub. First year, very early serial number.
When I bought it, I had no spark. Cleaned points, checked condenser, all were good. Coil unfortunately tested as failed (open high tension) I could see that the previous owner had done a poor solder job on it…
I’ve found a good Elto Ace coil/magneto I could purchase, but would be a purchase over a distance, so I cannot compare the size to see if it would fit a Cub.
They show as different part numbers, but does anyone know if you can interchange an Ace coil into a Cub?
October 3, 2017 at 1:41 pm #65698If only it were that easy!! They are too big. People are altering some type of chain saw coil to use. Don’t know coil info but maybe some one that does will post it.
October 3, 2017 at 2:38 pm #65700I have been looking into coil specs trying to find a listing of coil inside square, plus outside specs. Once we can find the sizes and what will fit then the next step is check the coil pri and sec windings. I think I have seen the Phelon pri and sec wiring specs somewhere? I do know the improvements over a square laminate, to a round laminate is a gain of about 20% with no other changes. That’s why you see round cores being used on motor cycle engines and anything that is pretty new.
So If we find a square coil make sure that it fits the laminate if lose make shims of magnetic steel to get it snug for best coil performance. That is all I know about it I am sure you guy’s know more about it than me the newbie.
Mike šOctober 3, 2017 at 3:27 pm #65701Thanks much Eltoquad. I was afraid of that.
Mike, I’ve been working on that solution for a while. Tried a Merc 4hp coil and just was too big (by .10" even after modifying it). I eventually ruined the coil trying to take off enough insulation to make it fit. Even pushed as small as I could make it, it still did not fit.
I’ve been evaluating chainsaw coils and have a few candidates I’m looking at purchasing. Expensive experiment!
If anyone happens to know the part number of a successfully transplanted chainsaw coil, please post it.
October 3, 2017 at 3:30 pm #65702Go on eBay to save you money on trying coils look on this seller theropshop more coils than you ever wanted to see. Don’t blame me for hours spent looking Like I did Ha Glad to see you are not afraid to cut stuff up.
October 3, 2017 at 11:54 pm #65716A member in Florida wrote a story about using the Mercury chainsaw coil on the Cub and Mate. We published it in the Outboarder about 2 years ago. E-mail me and I"ll send you the file of the article.
gemmanuel@bellsouth.net and remind me what you are asking for.
George
October 4, 2017 at 12:47 pm #65729Mike, thanks for that reference. Definitely a lot to sort through.
George, thanks for your offer. I’ve sent an email and look forward to your reply!
October 4, 2017 at 1:17 pm #65733One day I decided to go fishing in Silver Lake Wi.
But before I launched I decided to grab a burger at the local Dairy Queen
While I was rearrange things in the bed of my truck I can hear two guys talking
Ron you need a 25 hp like that guy
These guys look like fisherman- so called them over and showed them the 1920ās motors I was going to bring to Tomahawk
Wouldnāt you know it -the one guy is a member of AOMCI
We got to talking and he mentioned that his Father wound coils for a living way back when
And he had drawings of the outboard coils
I said that might be valuable to the club
I told him to send me copies and I will post them on the AOMCI web
I really donāt know too much about coil winding but maybe one you could use this infohttps://lh3.googleusercontent.com/25wG7 … 80-h604-no
October 4, 2017 at 3:22 pm #65737Biy would that be a great deal to see what the man knows.
Awesome I a old friend with a race engine shop and chassis Dyno Norm Brandes owns Westech. He does a lot of engine articles in Hot Rod magazine with another old friend Marlin Davis. I will call him and ask if he has any old outboard contacts.
You just never know who knows who …..pays to be polite to everyone. š
MikeOctober 4, 2017 at 10:14 pm #65750Is the Elto Pal mag the same as the Cub? Hopefully I’ll be picking one up this weekend along with a bin of parts, including a complete magneto assembly.
