Home › Forum › Ask A Member › Evaporust for Removing Rust Inside a Gas Tank?
- This topic has 7 replies, 7 voices, and was last updated 3 months ago by
JACQUES.
August 9, 2026 at 8:23 pm #326011
Have a 1939 Envinrude Elto Cub. Has some rust inside the gas tank. Gas tank is in ok shape.
Is Evaporust a good way to remove rust inside the gas tank? I plan to use the motor(not a wall hanger).
August 9, 2026 at 9:34 pm #326017Evaporust will work on the rust and is safe for paint, so its a good choice to use, especially on a small tank like that one. Hope this helps.
Best,
August 9, 2026 at 9:40 pm #326018Evaporust works pretty good, but I tend to use a product for etching cement
and / or de-rusting metal as it’s a lot cheaper.Klean Strip GKPA30220 Phosphoric Prep and Etch, Liquid, Green, 1.25 gal, Can
I get it at Home Depot.
Did you get the little Cub running last Thursday?
August 9, 2026 at 9:49 pm #326019Did not get the cub running on thursday. Steve & Ted worked on the poppit valve and got it running strong on friday. Got it home and it started, but then quit. Saw rust sediment in the fuel screen so decided its best to clean the gas tank.
August 10, 2026 at 12:34 am #326028I have successfully used double strength vinegar a few times to clean up fairly bad steel tanks. It is cheap and effective, just fill the tank and check every day or so. A short piece of chain can be added and shaken around in the tank to dislodge ant gnarly bits of rust.?
August 10, 2026 at 2:27 am #326033I like using Evapo-Rust to deal with rusty areas because it isn’t acidic and it doesn’t eat away at the good metal.
August 10, 2026 at 9:38 am #326046
Cub tanks are really thin. If you have rust some of the metal is already gone. An acid is effective in removing the rust but it removes good metal as well. Evaporust only removes the rust and a pint can should fill your tank. Cheap compared to finding another tank. As you have had gas in the tank you need to remove the oil left in it first. Evaporust is water base and the oil can keep it from getting to the rust.
August 10, 2026 at 11:46 am #326064if adventurous see several utubes using electrolysis to remove rusty coats
