Home Forum Ask A Member Evinrude 33HP Shift lever bushing and seal
  • #184357
    rvdriver
      We are trying to complete a rebuild on my lower unit and have it all completed with the exception of the shift level seal. How do you get to the seal? I see from the parts book that it’s a brass bushing, o-ring and a bushing gasket.
      I assume that there is a procedure to remove the bushing to put the new o-ring and bushing gasket in. Any thoughts or knowledge on how to get this new O-ring in place? Special tool required?
      Thanks,
      Steven
      The New o-ring with the shift lever
      #184361
      Randy in Tampa
        Requires a special tool, take off skeg turn it upside down and hit the tool with hammer, install with another one,Richard White might be making them?🤔
        Rotary valve Johnson’s Rule!
        #184365
          The tool to remove the bushing is OMC tool #304514. Available at Crowley Marine for around $12 or so. Or you can also use a long 5/16″ punch like this one to knock the bushing out.
          IMG_5044
          • This reply was modified 6 years, 5 months ago by Bob Wight.
          #184372
            David Bartlett
              I use Bob’s method also. 5/16″ punch works great!
              David Bartlett
              #184415
              rvdriver
                Thanks guys. Searching for a punch that will work!
                #184419
                  The punch shown in my picture is a Starrett #248D pin punch, available on-line at Grainger and several other sources for around $8.00.
                  #184421
                  David Bartlett
                    Bob,
                    I too have the Starrett punch set, but I also have a Harbor Freight set that has the same sizes. Nowhere near the quality but they will do the job in this case.
                    David Bartlett
                    #184703
                    rvdriver
                      I see the bushing and how you’ve described that it comes out, but it seems like the hole is too small for it to come out the other end.
                      It looks like the bushing a actually has a flange in it.
                      I’d love to see a video of this procedure.
                      Thanks for the help. I just want to Make sure I
                      Don’t mess up this procedure. It’s the last seal to replace before reassembly.
                      #184724
                      rvdriver
                        It almost looks like the bushing is in from the wrong end of the housing???
