Home › Forum › Ask A Member › Evinrude 4 horse folding motor mystery lever
- This topic has 9 replies, 5 voices, and was last updated 1 month, 3 weeks ago by
JACQUES.
September 18, 2026 at 9:16 pm #328725
My Son just got a 4 hp folding motor from his Grandpa. He is doing maintenance on it and came across this spring lever. Don’t have a manual yet, just the case and motor. Can anyone tell us what the lever is for? See pics
Thanks in advance!
JGG13
September 18, 2026 at 9:47 pm #328731some kind of handle or locking lever likely a handle see part 27 but more likely a lock release lever for the folding lu
Evinrude Motor Cover Group Parts for 1969 4hp 4902B Outboard Motor
September 18, 2026 at 10:15 pm #328733Hey Jacques, that is what we thought at first. However it does not connect to anything outside of it’s isolated housing. Thinking a vent but don’t know for sure.
JGG13
September 18, 2026 at 10:18 pm #328734looks more like a handle with that gold recess to slip fingers under. does the thing pull out a bit to facilitate transport ??
September 18, 2026 at 10:50 pm #328735have your son download this free 10th edition johnson service bible, J&Es are cousins anyway and he will find all the info he needs to service the carb, timing gear case etc…..
that kicker likely needs new ignition coils, condensers a small touch up on points and adjustment (see manual) .. may as well get some metallic strand plug wires 7mm if he is going to replace the coils. (DO NOT USE CARBON plug wires used on cars) lots of utubes on this needed tune up . Copper strand wire is best but any metallic strand wire will do … 0 ohms is 0 ohms on 18 inches of wire !
bike shops, lawnmower shops can sell you a few feet !
these wonder full 4hp twins are the best trollers for a small boat or as a back up to a bigger engine. it runs on 50/1 fuel oil but 40/1 won’t hurt it
http://www.youtube.com/watch?v=ga1Cjymj6ms&feature=youtu.be
socalaomci.com/library/johnson_service_manual_10th_edition.pdf?utm_source=chatgpt.com
September 19, 2026 at 8:02 am #328739fld the lower unit up and the lever goes over it and holds the lower folded in the up positio.
September 19, 2026 at 8:31 am #328740fld the lower unit up and the lever goes over it and holds the lower folded in the up positio.
Yes, this lever and pocket holds the gearcase in the folded position so it doesn’t just flop back down. It is critical that the tip of the gearcase is not snapped off though, or the latch won’t be able to help.
September 19, 2026 at 9:46 am #328744Thanks Guys!!!! It is a latch for storage as everyone here stated. Almost too obvious. Kid checked impeller, changed lower unit oil, checked compression, lubricated the cylinders, but forgot to pay attention how he unlatched it 😆.
Regards
Greg and John.
JGG13
September 19, 2026 at 12:42 pm #328748Great to see a young man getting interested in outboards!
"Every time you remove a broken or seized bolt an angel gets his wings."September 19, 2026 at 3:59 pm #328757IF granpa never had the coils serviced……up to you but pulling the flywheel should be next important step in case coils are cracked orn condensers heat up and short out . getting stranded from the dock is no fun when the coils pack it in
