Home › Forum › Ask A Member › Evinrude impeller pin question
- This topic has 12 replies, 8 voices, and was last updated 3 years, 7 months ago by
boscovius.
January 16, 2023 at 2:43 pm #271245
Hello all,
I managed to loose the pin that keys the impeller to the drive shaft. It looks like a 1/8” pin, approx .300” long is what is needed. I haven’t found a local source that sells solid pins and hate the idea of paying $7 plus shipping for a correct one if a simple roll pin will work (which I already have a selection of). Any words of wisdom on replacing the pin ? Unfortunately, I don’t have a metal lathe to make one.
thanksJanuary 16, 2023 at 3:07 pm #2712511/8″ stainless rod is readily available in most areas. Or how about an unthreaded section of a stainless steel screw?
January 16, 2023 at 4:52 pm #271258I would not advise using a roll pin.
January 16, 2023 at 6:00 pm #271267How about a piece of a nail? Maybe a welding rod stub? The flux will sand off an electric welder rod easily! How about a coat hanger? There are some that are close to 1/8″ Those prices are nuts!
dale
January 16, 2023 at 7:30 pm #271276deleted before to many see it 🙂 had my mind on propellers
January 16, 2023 at 8:33 pm #271288crosbyman this fella is looking for a drive pin for his impeller!
dale
January 16, 2023 at 10:02 pm #271302well that was in left field wasn’t it 🙂
January 17, 2023 at 12:28 am #271305I thought it was a very bad idea to use anything but the correct shear pin as the use of a material that has a much higher shear strength will defeat the purpose of the shear pin and allow the forces from a prop strike to damage engine internals.
When I was young and dumb I used sections I’d cut off from a brass rod my buddy gave me. they worked a bit, but were too soft and didn’t last long. Finding out exactly what the metalurgy is on those shear pins and getting a length of rod would be the way to go.
January 17, 2023 at 12:37 am #271308impeller pin…..:-) see post 271276 & 271288 !
January 18, 2023 at 1:36 pm #271380Thanks for the feedback. I was thinking that a softer steel might corrode too much. I recall that hardened steels tend to rust less and I think the original was a hardened pin.
