Home › Forum › Ask A Member › Gas Tank Sealer
- This topic has 5 replies, 4 voices, and was last updated 9 years, 11 months ago by
amuller.
September 18, 2016 at 11:18 pm #5293
I am looking for suggestions on a gas tank sealer. I am working on a tank that has several pin holes that I would like to seal from inside. I’ve seen a few items on the internet but thought I’d check here first. I’ve seen a product sold by Bill Hirsch auto and one from Caswell. I’m up for suggestions as to how best to seal the tank. Thanks Jim
September 18, 2016 at 11:59 pm #44275Recently, after a bunch of reading about this, I used POR-15 Fuel Tank Sealer. (They make other stuff also). I think this is a moisture-curing polyurethane product. My report is so-far-so-good. It seems to cure very hard and so far–but I have only a few weeks to go on–it seems to be resistant to typical 10% ethanol motor gas.
People are also using it for sealing cork floats.
One suggestion based on my experience: The stuff is loaded with metallic pigment. I presume aluminum. Shaking is not enough to mix this–it needs to be stirred with a bottom-scraping action. I didn’t realize this, not supposing that a tank liner product would be pigmented. When I got to the bottom of the can it was very thick and gloppy.
There are two-part products around that might have a higher performance.
September 19, 2016 at 12:12 am #44277Thank you for the suggestion. I’ll check up on that product.
September 19, 2016 at 12:25 pm #44299Yup – Por 15 works great. It’s expensive, and you must follow the directions, but it will seal all the leaks. I used it on my 1947 Sportsman built-in tank back in February and no leaks to date.
September 19, 2016 at 12:38 pm #44300Red-Kote also works well and like the other will also seal holes and such…..
I have sealed several with it and had to date no issues known.
classicomctools@gmail.comSeptember 20, 2016 at 6:11 pm #44393I just resealed a couple of 6 gal tanks. It went like this: (1) pint of acetone sloshed around and left for a couple of days. (2) hot water, stones, and TSP sloshed around. (3) phosphoric acid etch. (4) tank sealer. quite a pain, actually, and I doubt any tank coating will work without effective cleaning down to bare metal.
Then, add cleaning up and painting the outside of the tank, and the various little springs and O rings and gaskets that may need attention, and the cork gauge float, and the inlet screen, and the gasket in the filler cap which likely is shot …….
