Home › Forum › Ask A Member › hot 9.5 for 75$
- This topic has 13 replies, 8 voices, and was last updated 7 years, 11 months ago by
Don.
April 27, 2018 at 11:58 am #9754
I may be able to get this one but do you think it is worth while
engine seized …overheated due to bad impeller
April 27, 2018 at 1:15 pm #74860Personally I don’t think it would be worth it to make a runner, but the parts value is a lot more than $75. The recoil starter alone will bring more than that on eBay.
April 27, 2018 at 1:59 pm #74863I agree, I’d buy it for parts, but I have had one of these forever – Dad bought my 1969 used in 1973. It has pushed everything from a pontoon to a hydroplane, but I hate working on it – I’ve been through all common problems – exhaust leaking into the engine housing, bad rubber mounts, broken recoil spring, worn out tiller, etc. and all these things take way too much time to fix. I will now only fix the 9.5s for anyone else if they are a close friend.
DaveApril 27, 2018 at 2:53 pm #74865I had a ’66 9.5. Best motor I ever owned, I regret everyday selling it.
April 27, 2018 at 3:57 pm #74867I’ve often heard the 9.5 described as a motor that people either really love, or really hate. I have to admit the low profile is nice for fishing/trolling.
DaveApril 27, 2018 at 6:22 pm #74878ok thanks.. I had him drop to $67.50…. and was going to pick it up ………then he chicken out on the deal
I’ll wait him out a few weeks and if still on kijiji………. i’ll reoffer 75$
I have a turtle to test out but it is and ugly dirty thing which had a 2 inch lobotomy in the cowl just above the carb
If I can get the 75$ one it is worth the prop alone ! ……patience brings joy
thanks for opinions
April 28, 2018 at 12:32 am #74902It’s a bear to work on without dismantling it entirely, especially with its integrated carb.
IMHO if the rubber exhaust seal is still in good shape then it’ll make a nice runner. Last time I tried to rebuild one, the seal was nla and the lower part of the motor took in so much water it almost went up the exhaust ports.
I believe I’ve seen some sites advertizing 9.9/9.5 exhaust seal repro.
April 28, 2018 at 2:48 am #74909Keep in mind the exhaust problem that makes it idle bad with the lid on, can be either the boot between the housings or the shift rod bellows – both discontinued.
DaveApril 28, 2018 at 3:12 am #74910Nymarine has the shift rod boots and the exhaust boots.
April 28, 2018 at 3:24 am #74911 -
