I have a 1925 Johnson A25. It runs quite well, starts right up. I have noticed that after running for about 10 minutes or so I start to hear a whirring noise, that does not seem to come from the power head. I use the recommended oil mix of TCW 1/2 pint to a gallon of gas and no apparent problems, no knocking, no over heating. I wonder if the noise could be coming from the lower unit or the water pump. I regularly take the lower unit apart at the end of the season to drain out collected water, and change out the John Deere corn head grease. I note very little lateral play in the prop shaft, and almost no perceptable end play in the prop shaft. There is considerable wear on the gear teeth, with pitting noted on the pinion gear teeth and the prop shaft gear. There is about one inch of gear lash as measured at the outer circumference of the propellar. So is this noise “normal” for an hundred year old outboard motor? Anything I should be doing differently, or adjustments that need to be made in the lower unit? Thanks Jonathan
