Home Forum Ask A Member Johnson A,OA, 200 and F hot starting.
  • #236659
    jim-moffatt
      Does anyone have tips as to how to best start one of these motors when it has just been stopped?
      #236680
      wbeaton
        If the motor is in good tune it should only need a single pull of the rope when warm. Anymore than a few pulls and it’s probably flooded. Close the fuel needle, set the carb lever to fast, timer at 6 o’clock and pull the rope until it starts. That’s been my experience anyway. I just happened to work on three of the A series motors this weekend.
        Wayne
        Upper Canada Chapter
        uccaomci.com
        #236799
        PM T2
          I had an OA-60 a long time ago, and it liked it rich when restarting, even when hot.
          That bein’ say-ed – these things also tend to flood easily, my P-30 is picky that way. Any hot re-start after even the briefest of shut-downs usually requires closing the needle valve then reopening it after the engine fires up.
          By contrast, my F-70 is a good girl, and requires no special treatment to get started, hot, cold, or anything in between.
          All of my A series Johnsons (I consider the BN to be one of them) are good at restarting on the first pull when warm. I do habitually turn the fuel petcock to closed anytime I shut them down, even if its only going to be for a few seconds. The exception to the one-pull rule seems to be Johnson # 3999, which I currently have apart. When it was warmed up, it was still necessary to choke it and open the needle valve to get it to re-start. The piston rings were stuck in their grooves on the starboard side piston, so I wonder if that was a contributing factor.
          I’m assuming your OA is an easy starter when cold?
          Best,
          PM T2
