Home › Forum › Ask A Member › Johnson FD-11 powerhead on FD-10
- This topic has 13 replies, 6 voices, and was last updated 2 weeks ago by
RICHARD A. WHITE.
October 15, 2026 at 4:48 pm #330101
Hello,
I want to replace a stuck 15hp FD-10 powerhead with a good 18hp FD-11 powerhead on the FD-10 driveshaft casing. Can I use the FD-10 magneto, flywheel and carburetor on the FD-11 powerhead?
Thanks!
October 15, 2026 at 7:15 pm #330111so question… what is stuck on your FD10 ..gear case, powerhead innards stuck rings only , rewind starter …etc…
October 15, 2026 at 7:36 pm #330113The powerhead. Tried to unstuck a number of times, no luck.
October 15, 2026 at 10:22 pm #330119My Johnson common parts book says the FD-10 and FD-11 share the same part number on the flywheel but the magneto plate and carburetor have different part numbers between the 2 motors. Not sure if that really means those parts are actually different from motor to the other or just a revised part number. I can’t imagine the magneto plate would really be different between the two, especially since they share a common flywheel.
"Every time you remove a broken or seized bolt an angel gets his wings."October 16, 2026 at 7:04 am #330130took me a whole week to free up a $50 9.5hp 9622a by removng the cyl head, soaking the rings and alternately wacking the cyl tops with a round 1 incnch wood peg. Suddenly movement began with the FW moving a few degrees progressing to a full release. Became a great troller along side my 75 ETEC
October 17, 2026 at 8:33 am #330167I can understand the different carb, but the different mag plate is intriguing. I’m wondering if the original 15hp mag plate number supercedes to the 18hp mag plate.
October 18, 2026 at 1:01 am #330208Check if the base gasket matches to start.
October 22, 2026 at 8:50 pm #330424Thanks for everyone’s input!
October 23, 2026 at 8:44 am #330440I would do more research for you, but don’t have access to the 15hp parts book. The powerhead/base gaskets are the same, so the powerhead will fit just fine, it is the different mag plate numbers that intrigue me.
October 23, 2026 at 9:45 am #330443Different mag plates would more than likely be attributed to where the throttle cam pickup is attached to the underside and such…By keeping the FD11 parts together, you mitigate most of the issues I would think.
My guess would be bolt the whole later powerhead on, mag and all, so long as the recoil and cowl don’t interfere.. just my .02
And I am no expert..
classicomctools@gmail.com -
