Home Forum Ask A Member Johnson FD14 18hp 1960 Impeller
  • #8682
    piddler
      Hello
      When I tighten bolts on my lower unit. After I installed new impeller I cannot pull through my rope starter. When loosened a little it will pull through??? Know what causes may be?
      Thanks in advance Piddler
      #67514
        Is it a Sierra or OMC impeller ?
        It has been said that Sierra impellers are thicker than they should be.
        Steve A W
        #67516
        johnyrude200
          Put grease in the impeller housing when you first install. Normally water lubricates it but this also makes it easier to re-install the new impeller when you slide the housing down over it, and discourage damage to the new pump if pulling over dry.
          You only need to put a dab of grease in there not a huge amount. Once it rotates a couple of revolutions it will be spread all over the place.
          #67518
          fisherman6
            If the impeller was thicker than it should be, it would make the engine difficult to turn over if the impeller housing screws were tightened all the way and easier if they were loosened.
            I understood the situation as the screws that hold the lower unit to the midsection being tightened is what is making the engine hard to crank. I don’t see that the impeller would cause this at all. This sounds more like something is bent or being forced out of square that is causing the drive shaft to bind to me. Maybe I’m misunderstanding the situation, though.
            -Ben
            OldJohnnyRude on YouTube
            #67519
            piddler
              What could be bent? Nothing appears to be. 3 items copper tube, drive shaft, gear shift rod all appear ok. I will try the grease as I did not apply any. I did tighten down impeller housing tightly (3 Screws) Perhaps if impeller is TOO tall it would bind. But loosening lower unit case bolts should not change this Correct?
              Thank you for you help
              #67520
              johnyrude200
                If the gearcase screws being loosened fix the tightness, its not the impeller and vice versa.
                #67523
                fisherman6
                  Maybe nothing is bent, just out of square? Is it possible there is something between the lower unit and the midsection at one or two of the screws? Just enough to cause it to tilt a little when it is fully tightened? I don’t know what is causing it, but something must be binding. Did everything work properly prior to changing the impeller?
                  -Ben
                  #67526
                    Then it could be too much grease on/in the crankshaft spline forming a hydraulic lock, or the wrong (too long) drive shaft. . . 🙄
                    #67530
                      First, pull the lower unit off, leave the pump on and see if you can turn the drive shaft. With grease (I prefer soapy water) in the impeller housing, you should be able to turn the drive shaft with your hand, although there will be some resistance.
                      #67531
                        Look up inside the housing inside the crank where the drive shaft fits. Look for traces of debris or the old o ring up in there. Do not put grease on top of the drive shaft when installing, only the splines and o ring.
