Home › Forum › Ask A Member › Johnson JW-16 3 hp This and That
  • #237708
      My brother-in-law dropped off a couple of outboards that he’d like new impellers
      and L.U. seals in.
      I have the JW tore down already, and noted that there’s a pretty deep
      groove where the driveshaft seal rides. Not sure there’s much room
      to adjust the new seal in a different place or not, but perhaps.
      MarineEngine does sell new driveshafts, but not sure if my B-I-L is going
      to want to spend $100 for one.
      I noticed that the driveshaft has the same splines on both ends, and the same
      length of splines, but the top side splines has a square cut o-ring groove in it.
      Q. Have any of you flopped the driveshaft around on these JW’s after machining
      a o-ring groove and drilling a little hole for the impeller drive pin?
      When I pulled the driveshaft out of the power head, there was no o-ring in the groove.
      Didn’t see chunks fall out either.
      Q. Is there any way the o-ring could be “stuck” up in the power head?
      Doubt if I can see up there with a flashlight, and don’t plan on pulling the
      power head! Thanks.
      DSCN0827
      DSCN0828
      DSCN0820
      DSCN0825
      • This topic was modified 5 years, 4 months ago by Buccaneer.
      #237715
        interesting option to flip and regroove the shaft for a O-ring….
        if your b-i-l balks on a shaft for $100 just tell him he will get himself a running kicker which does not seem to bad considering the cost of a new eqv HP motor+ taxes ๐Ÿ™
        JW are good little motors for trolling and… not-rowing back to shore ๐Ÿ™‚
        Joining AOMCI has priviledges ๐Ÿ™‚
        #237738
          Well, flipping the driveshaft would require drilling another hole for the impeller pin…I wouldn’t chance it…Find a decent used driveshaft….
          The oring could be stuck up near the powerhead, but I doubt it…
          Tip the powerhead upside down, spray some WD40 down inside the crank splines.. Manually insert the driveshaft in and out of the crank several times to clean out rust/old dried lube. Tip the powerhead back upright and insert the driveshaft only about half way into the crank splines and try rocking it back and forth to see how much play/wear might be present in the crank splines… Your pictures aren’t that clear, can’t really see the wear in the seal area, but the upper splines appear to have some wear.
          Was the gear oil milky/watery when you drained it? Perhaps the gearcase was holding oil OK in spite of the groove.
          This becomes a judgement call at this point. Obviously your beloved BIL doesn’t want to spend a nickel on this thing, but expects it to be like new after you get done with it…If the gear lube looked “OK”, you may just want to put the thing back the way it is before getting in too darn deep on this project…
          #237744
            or…just tell B_I_L to by a gallon of 90 grade oil and change gear oil a few times during the year or twice a season for ice fisherman.
            colonoscopy the power head grooves ๐Ÿ™‚ for comfort
            #237750
              Thanks for the replies. I’ll see what route the BIL wants to go with it.
              The gear case oil was pretty good, and he didn’t notice any leaks
              on this one.
              The carb must not have been run out of gas last time used. It was laying on it’s
              side when delivered, and when I stood it up, gas and crud ran out
              of the lower unit driveshaft housing drain, and some out of the
              water pump intake.
              I just bought a milling machine, and if it was “my” motor, I’d be
              trying to drill a hole and machine a groove to flop the driveshaft
              end for end. Think I’d find an old driveshaft on a scrap motor
              to practice on first though.
              The splines looked good at first glance, no rust or other signs of water
              messing up the splines on either end, nor the gears.
                I did a little experimenting with a scrap driveshaft from a Gale, to
                see how hard it would be to flip the JW’s driveshaft “end for end”
                to have a good surface for the driveshaft seal.
                With the DRO and edge finder, locating the exact spot to drill
                was no problem at all. I drilled an 1/8″ hole with a center drill,
                but I need an 1/8″ endmill to make a “flat bottom” hole the correct
                depth for the impeller drive pin. Said end mill on order.
                The other item of concern is a new o-ring groove on the driveshaft,
                where it goes into the power head. I didn’t think a parting blade would
                be the best weapon to use on an interrupted cut in the splines, on a hard shaft,
                so I made a holder today for my Dremel to mount in the lathe tool
                post. I installed a little “cut-off” wheel in the Dremel and it appears
                it will make an o-ring groove if one feeds “slow and easy”.
                Brother in law said to “go for it”. If it turns out okay, I’ll report back,
                otherwise, forget you ever read this!
                DSCN0845
                DSCN0850
                  Good luck with it – hope it works!
                  1982 Evinrude 25hp
                  โ€œEvery 20 minute job is only a broken bolt away from a 3-day project.โ€
                  #238018
                    I admire the will of many in the club to do walk-arounds to solve problems. Sometimes I do them, too. The milling machine sure adds a lot of potential. So that being said, I feel like a kind of Negative Nellie but I am concerned about how the pinion gear is going to hold squarely on the shaft, with the old o-ring groove in it. In a three, the drive shaft is held square by the shaft, not a bearing. The only things the gear housing does for the pinion is have a bushing to stop upward movement of pinion and hold the drive shaft laterally. I’d also be worried about the groove damaging the bushing, depending where that groove ends up running.
                    The best equation ever written is Time=Money. In this case, YOUR time equals HIS money. $100 for a brand, spanking new drive shaft really isn’t that bad. I’ll shut up now.
                    #238025
                      Bill, I’ll recheck this morning before I do any machining on the shaft,
                      but I think the o-ring groove is not riding in the bushing, but yet
                      high enough from the end, where the pinion gear will have lots
                      of contact area on the splines.
                      Thanks for mentioning.
                        just add the o-ring both ends
