Home › Forum › Ask A Member › Johnson LS37 carb hole
  • #231897
    Mike M
      Could anybody tell me what the hole in the bottom of my LS37 carb is? Or send me a picture of the bottom of a LS37 carb.. thank you
      #231900
        I wonder if that hole is original, or if someone decided to let excess fuel “out”, or more air “In”?
        Mike M
          Yea it doesn’t appear to be threaded.. I have blocked it with a paper towel just to see and it starts a little easier and it seems to start easier.. it starts good on test bench but will not stay running in the test tank.. it’s got to be a air intake I’m thinking..or like you said drilled out for some god forsaken reason..
          #231906
          Mike M
            On the poche website it points to bottom side ports to clean but can’t tell if it’s a hole or some kind of plug?
            #231921
            Rusted Junk
              Hi Mike,
              All three of my carburetors have that hole in them I believe, I will double check tomorrow when I get to my other shop where I have the motors, I just recently went thru two of those carburetors on my TS20’s . I will attach a picture for you.
              Steve
              #232003
              Rusted Junk
                Mike,
                Attached is a picture of the hole I’m my Johnson TS 20 Carburetor. I have three of theses motors and all have that hole in them.
                Steve
                #232010
                Mike M
                  Thank you
