Home › Forum › Ask A Member › Johnson MS38/MS39 Advice Request
- This topic has 13 replies, 5 voices, and was last updated 48 minutes ago by
Mike Barthel.
November 16, 2026 at 10:49 pm #332297
Its not going to run with only 25 lbs compression. Since you cant get it to run I would suggest taking off the cylinder to see if the rings are stuck. If not, carefully remove the top ring. You don’t want to break it. Position the ring at the bottom of the cylinder, and use something close to the same diameter of the cylinder to get it straight, then check the gap. When new it was probably .005 to .007. .010 to .012 wouldn’t be to awful bad, but something like .030 would be excessive, indicating the ring is worn out and there is likely significant where in the cylinder as well. Then push the ring down so its near the top. The difference in the gap from the bottom to the top will give you some idea how much taper there is in the cylinder. It’s really difficult to check the gap, with feeler gauges, when the piston is at the top of the cyl., in these small cylinders. While this doesn’t give you a precise measurement, a difference of only a few thousand, from top to bottom, may indicate the cylinder doesn’t have much ware. If you find you have what looks like this example you need to find another power head.
November 23, 2026 at 2:07 pm #33281011/23 update…
I removed the power head. Every gasket was in poor condition except the exhaust flange gasket, and the power head is heavily coated in soot. The cylinder, piston, and rings looked clean, well oiled, and worked perfectly. I don’t have feeler gauges on hand, and doubt that those parts are a problem. The lower unit parts appear corroded and have bad gaskets as well. Next, I will disassemble the lower unit and clean the power head as thoroughly as I can.
November 23, 2026 at 3:11 pm #332816As for gaskets for this motor, there is a member here that is making gaskets for this motor. I just bought a set off Ebay for my MS15 that worked very well. It did a need a little grinding with a dremel as the bore on the MS15 is a little larger than on a MS38 or 39.
November 23, 2026 at 4:03 pm #332829Yes, MS 38 gaskets are available on eBay, so that isn’t an issue. Just need to spend quality time cleaning the spots that need it, and leaving the spots that don’t. Thanks JOHN D.!
