Home Forum Ask A Member Kf7 carb
  • #259558
    Mallett
      so I got the kf7 on the flyer it started fine,I let it  warm up a for minute or three moved the timing advance up to fast, squeezed the hand throttle off we went, it was  great! Ran for a few minutes gave it the full throttle a couple of times it’s fast. Then it seemed to bog down not have the top end it starts and idles putts along. So probably need to clean the carb jets any advice before I dig in?
      thanks
      #259559
      Mallett
        67346453965__7949E04D-AC7A-4273-A3E1-682EFA25686F
        Here she is!
        #259562
          Carb is simple enough except for the spring
          on the choke plate. Takes a little practice getting
          it back on. Old packing washers can disintegrate
          leaving chucks plugging things up so that worth
          checking but are you sure something hasn’t just
          slipped or become disconnected?
          #259567
          labrador-guy
            Check the fuel filter in the tank also!
            dale
            #259585
              dale
              Ditto.
              #259586
                And the fuel line.
                #259597
                Mallett
                  Tubs what’s the small adjustment screw to right of the fuel shutoff, and how does one adjust it properly?
                  #259598
                    High speed adjustment run at full throttle and adjust to best running.
                    #259608
                    Mallett
                      Thanks tubs, that’s a nice looking carburetor. I don’t see a filter in the copper fuel line or the tank.
                      #259612
                        The original filter is (or was) here. It could
                        have been removed. The ones I have had still
                        have the factory filter so I don’t have any
                        experience with actual substitutes. I’m sure some
                        more knowledgeable than me will help you
                        out there.
