Home Forum Ask A Member Kf7 carb
  • #259619
      call me if you need the in-tank filter replacement.
      1 914 310 7086.
      #260768
      Mallett
        Ok you guys we’re right, it wasn’t the carburetor it was a loos plug wire. It run fine for a couple of tanks of gas. Then it happened again after I hit some big wake and flew out of the water I checked the plug wires there were connected, it runs a little with the choke out but is stalling out. The gas valve knob turns  real hard like it’s tight and I notice some stains on the garage floor under the motor. Gas is leaking from the carburetor? Maybe the float is sticking and leaking by? Then the cotton cover is starting to come off the pull cable, any advice on that or the carb?
        #260807
          Take of the fuel shut off. Gas should run out.
          Collect it to check for dirt. Next would be the
          carb. Disassemble and check for dirt (pieces
          from a dried up packing washer).
          #260835
          Mallett
            Thanks tubs, I did that the gas knob turns much smoother I pulled it apart cleaned it the washer and gasket looked ok. The fuel had a fair amount of chunks the filter in the tank looks ok I haven’t been able to get it out of the tank feels like it’s seized on there. A lot of junk came out of the fuel line. I should get the gasket for the carburetor before I pull it off. I was thinking about spraying some carburetor cleaner in there today. The compression fitting on the gas valve is leaking a wee bit. Are those standard plumbing parts I was going to make a new copper fuel line.
            #260836
            Mallett
              Is there a washer in the tank on the fuel filter, if that was bad gas would probably be leaking at the tank.
              #260838
                Should be able to reuse the bowl gasket.
                Referring to packing washers – seals for the
                mixture screws. To get the filter assembly
                out I clamp it in a vice and spin the tank.
