Home Forum Ask A Member Kiss of death?
  • #221437
    davidk
      This is a mag plate from a 1936 Thor Sea King single. While cleaning the grease and dirt I discovered the break in the clamp. I wish I could unsee it. Anyway to repair this? Seems unlikely……
      IMG_4274
      IMG_4276
      IMG_4275
      #221442
        If there’s a will, there may be a way. Perhaps
        the ring could be drilled and tapped and a
        couple of #10 machine screws used to hold
        the broken piece together?
        • This reply was modified 5 years, 3 months ago by Buccaneer.
        #221447
          tried those aluminum welding rods ?? maybe STEEL WELD epoxy ???
          a welding shop could be usefull shouldn’T be to hard to weld and polish it off
          #221461
          Monte NZ
            International Member
            I would bolt the broken part using suitable packing, to line it up correctly,
            then remove the broken part and V the break with a grinder, place it back correctly with the packing and have it aluminium welded and then remove the holding bolt plus the packing.
            You could then if you wanted to finish the job properly, remove the holding bolt and fill the hole with weld.
            Monte NZ
            #221462
              It looks to me like that is a design that was just begging to break, anyway. I am not a welder but I would be surprised if welding it, even by a pro, would hold. Is this motor going to be a full restoration or just get ‘er goin’ and take a spin? If a full blown restoration, I would try to find a parts motor. If just running it for an hour or so, I would try using it just the way it is. It seems like it will still tighten enough to create enough friction to hold the plate from moving. I have a Mercury-built Thor single. It is no prize, when it is running. It sounds pretty unpleasant. If it were me, I would not sink a ton of time and money into that one you have. Just my opinion.
              On another note, it says, “American Bosch, Springfield, MA.” Don’t Wico and Phelon also come from Springfield? It must have been the magneto capital of the world!
              #221464
              davidk
                Thanks for the input, everyone. All helpful and sound advice!
                I agree with you, billw, that this motor is unlikely to be a good runner even if I get through a restoration. I won’t go deep into it. Funny thing is, the plate was very hard to move when it was on the motor. I thought I was doing the right thing taking it off to clean out the dried grease. Now I wish I could reapply it. Anyone have an extra tube of dried grease?
                #221469
                wbeaton
                  I have a Caille like that. The previous owner put a thin steel strap across the crack and bolted it down. It works really well. I have since found a good replacement mag plate, but I don’t run this particular motor so I didn’t bother changing it. Your mag could be welded and machined though it may break again. Aluminium brazing rods won’t work for this repair.
                  Wayne
                  Upper Canada Chapter
                  uccaomci.com
                  #221470
                    #221473
                    labrador-guy
                      Here is my two cents on this project. I would take the pinch bolt out and get a proper size hose clamp to go around the housing and use the clamp to tighten it up for some tension.
                      dale
                      get’em wet don’t let’em set!
                      #221478
                      davidk
                        More good suggestions, thanks!
