Home Forum Ask A Member Larson 4 HP 1 cylinder outboard
  • #252556
    WARREN PINNEY
      I recently acquired a 1 cylinder 4 cycle outboard. I am looking for a maintenance manual and rear lower over. Can anyone help me out?
      #252558
        is it a 4hp running on 1 cyl or a 1 cyl running as a 4 stroke ?
        Joining AOMCI has priviledges šŸ™‚
        #252560
          Warren, I have a pdf file for the Lauson S350 / 351 but it’s too
          large to upload here.
          If you PM me your email I could try to send it via “We Transfer” online.
          JOHN D.
            I think he may have the earlier 410 model. That’s a 2.5hp motor and is different from the later S 300 line of motors. Is the lower cover cast aluminum or stamped?
            #252834
            WARREN PINNEY
              It is a single cylinder Lauson, SN: 70B7480 no other markings. May be less than 4 HP.
              #252854
                Does it look like this motor?
                #252929
                WARREN PINNEY
                  Thanks. You are right That looks like it. Probably a model 410, 2.5 HP with a rope start motor. The rear back cover is missing, can I operate it without fear of it overheating?
                  #252933
                    No.
                    You can maybe barrel run it for a little while;
                    Without the cover in place it will overheat.
                    #253031
                    lauson73
                      I am the LausonĀ  person listed in the Antique Outboader Magazine and I have all parts and repair manuals for
                      every model of Lauson. I have close to thirty of these Lausons and many parts motors. I have the cowl,
                      and you need the cowl for correct air cooling.
                      Send me your email and I will get you the Manual or call me @ 541 948 0866
                      Doug Grell
                      Lauson 73
                      #253073
                        Doug
                        Email sent.
                        Thanks
                        Steve A W
