Home Forum Ask A Member Mark 25 Fuel Issues
Viewing 5 posts - 41 through 45 (of 45 total)
  • #67160
    cheetahgod
      Yeah I adjusted the spring and lever to what the manual says
      #78090
      cheetahgod
        Now that the weather is warmer here in cali I have been working on my mark 25 today. Replace the float and started it up. Its running at too high rpm in idle. It revs up then slows down. Also when priming the engine gas spurts out of needle thing so I may need to adjust the float lever? Here is video: https://youtu.be/S2cJOqXUZ2s
        Thanks for all the help so far.
        #78098
          your problem mat be the exhaust being sucked in the carb. use a fan to keep it away from the carb.
          #78102
          jw-in-dixie
            Gas spurting out just means that the bowl is full – stop pressing the button.
            #78104
              10-4 J.W.
              float leaking or jets incorrect, The others need corrected, hard to say who has " Tinkered" 😮 Good job on the pumps!!
