Home Forum Ask A Member Martin 100 ST Model mishap
  • #197984
    RICHARD A. WHITE
      Ok, I can access the one in my shop, I have to get to the one out in the shed as it is probably the one that would work but it is 8 feet off the ground and behind a 4,000 popup camper…I will respond here if it is the right one… I just need one but not sure if I can add one one that does not match yours to my motor and make it work…
      classicomctools@gmail.com
      #197985
      oldemtr
        You got me worried, Birney – I just went and checked mine, and the bracket looks fine.
        It is just a thin wall casting, probably strong enough in use, but I could see that a hard shot to the tiller, or dropping the motor on that side, could get a crack started.
        Since Larson says breakage is common, I’m thinking of ways it could be reinforced, without changing the appearance of the motor ……
        #197991
        mercuryman
          Russ thinks users pushed down on handle to tilt motor. I think if you don’t abuse it , it should be ok.
          #198002
          squierka39
            Now I have to go inspect my 100’s and make sure they have no crackers starting.
            #198902
            mercuryman
              Got the motor running in a barrel. I got a handle bracket from Russ Larson.
