Home Forum Ask A Member Merc Mark 7
Viewing 10 posts - 1 through 10 (of 28 total)
  • #2479
    cark-k
      My brother bought this Merc Mark 7 for me this morning in Northern NJ. It looks to be in great shape, compression etc but has crud in the tank. I would appreciate any help in determining where to start with getting her running. This is my first vintage Mercury so I don’t want to mess it up, could use some information on the motor, year etc. Thanks, Carl
      #23451
        the guy sold it out from under me. I was picking it up tues AM.
        call me for info 1 914 310 7086.
        557618- 56417- 1953
        761134- 762112- 1954
        825148- 825417- 1955
        check impeller check coils and points and condensors clean fuel system
        #23457
        Doug Wilson
          just finished one up yesterday clean the tank out if it is too bad put some super clean and small chain in and shake around then let soak few min shake again and dump it rinse well with water couple of times if still has gunk repeat. replace fuel filter take carb off and clean well and coat float with clear fuel resistant airplane dope replace gaskets on carb check coils clean and adjust points . replae impeller and put fresh lube in lower unit.
          to start out idle screw about 3/4 from lightly seated and high speed about 1 then fine tune on boat
          Doug
          turned off?
          #23459
          cark-k
            Thanks! Are impeller’s available if needed?
            #23462
            Doug Wilson
              check with marine engine or vintage outboards think my carb kit and impeller came from vintage outboard. fuel filter came from old mercs
              mine stars on the first pull real pleased with it may take getting used to not having reverse or neutral .
              Doug
              turned off?
              #23467
              RICHARD A. WHITE
                quote ddwilson:
                Starts first pull??? WOW nice motor…lol
                classicomctools@gmail.com
                #23483
                cark-k
                  Is the fuel filter in the tank? Thanks for all the info.
                  #23484
                  Doug Wilson
                    The filter is in the tank it is attached to the hex fitting that the fuel line comes out through. Takes a large wrench and should come out some of the original filters swell up and do not want to come out. They will but takes some work. When you order a filter order the gaskets for the tank too not very expensive but worth replacing while it is apart.
                    Doug
                    turned off?
                    #23485
                    Doug Wilson
                      Richard yes it turned out to be a nice motor. May end up repainting the tank and lower shroud eventually but will enjoy it the way it is this fall.
                      Doug
                      turned off?
                      #23498
                      cark-k
                        Thanks. I’ll have to pick-up an 1"-1/8th socket to break the nut loose. The tank has a thick black coating inside, got some of it out with a coat hanger with a gas soaked rag attached but cant get to the front of the tank. All the gas line fittings were completely blocked. 😀
