Home Forum Ask A Member Mercury KE-4 Rocket
  • #316232
    Aidan Smith
      Getting my KE-4 ready for the water this weekend.
      Runs, but has a pretty bad misfire that I believe comes down to a failing condenser on the bottom cylinder. Coil is good, and has great spark when turned by hand. I am thinking that the condenser, when heating up, is shorting out.
      Does anyone know the microfarads of the original Phelon condensers? I’d like to either rebuild or replace them with newer alternatives. I’ve had good luck with gutting the old ones and rebuilding them.
      I had a .22 uF OMC condenser in there just for testing, but never actually ran the engine with them.
      Thanks!
      1949 Mercury KE-4
      1952 Mercury KF-3,-5,-7
      1952 Mercury KG-7Q
      1937 Evinrude Scout
      1938 Elto Pal
      1946 Evinrude Ranger
      #316235
      RICHARD A. WHITE
        Find out the part number of that condenser…. go to:
        Members only section..
        Inner Sanctum…
        Old iron reference library…
        Manuals…
        On the right under Mercury you will find the Mercotronic manual… 168 pages I believe… in the manual you will find the specs for that condenser and sooooooomuch more, coil specs for a whole lot of motors…. Took me seemingly forever to scan all of those for member use.. Print it off, so that if someday you find one of those testers…you will already have the manual….
        Enjoy
        Richard
        classicomctools@gmail.com
        #316241
          If that doesn’t help, and it continues to get worse, suspect the lower crankshaft seal.
