Home › Forum › Ask A Member › Need 1956 Johnson CD-13, 5.5 Hp Lower Unit Seals
- This topic has 7 replies, 5 voices, and was last updated 1 month, 2 weeks ago by
LARRY CATON.
September 21, 2026 at 7:21 pm #328889
I looked in the Classified section and didn’t see any members selling seals or kits. I also looked online and wasn’t having much luck. I know we’re not supposed to sell items in the Ask A Member section, but I need help finding parts.
Can somebody point me in the right direction to find these seals?
300599 Drive Shaft Seal below water pump wear plate
303345 Seal –aft prop shaft
303360 O-Ring, prop shaft
303328 Seal, spaghetti
I have the seal for the shift rod, and maybe the spaghetti seal. IDK if different gear cases use different diameter spaghetti?
1956 Johnson 15 Hp, FD-10
1957 Johnson 5.5 Hp, CD-14
1958 Johnson 5.5 Hp, CD-15September 21, 2026 at 7:51 pm #328891check with the folks at vintage outboard for kits I used .103 spaghetti last time I did mine make 100% certain the clutch is not stretched before closing up !!
call them up for exact kit#
September 22, 2026 at 9:13 am #328908If all else fails, you can try sourcing seals via “size” using
the lookup link here….
CR Seal FinderAlso, McMaster Carr sells the spaghetti seal in bulk.
Search on site for the size, I know it’s been brought up before.Prepare to be boarded!
September 22, 2026 at 9:18 am #328909I’m pretty sure they are all still available, did you look on marineengine.com?
September 22, 2026 at 3:09 pm #328922Seal kit for that motor is Sierra 18-2679. Includes all the parts and pieces you noted.
"Every time you remove a broken or seized bolt an angel gets his wings."1 user thanked author for this post.
September 23, 2026 at 12:25 pm #328955Hi Jacques,
When you say to make sure that the clutch isn’t stretched, are you talking about what the parts book calls the “pinion shaft and shock absorber assembly”? Does that lower shaft & assembly just pull out by grabbing the pinion gear?
Since I haven’t done this before, IDK what normal vs stretched looks like, or what the remedy is if it’s stretched.
Do you know if there’s an existing post about it, or if it’s in “the Red Book”?
Thanks so much!
1958 Johnson 5.5 Hp, CD-15September 23, 2026 at 1:11 pm #328957the clutch (SHOCK ABSORBER) spring will sometimes break causing it to strech enough to cause rub marks on the underside of the water pump and as was my case….. caused all sorts of headhaches cloosing up the LU . it repeatedly failed pressure testing until i realized the problem.
I had my friend tack weld the thing at 6″11/16 on 3 spots around and made certain the welds did not protude …we simply polish them up with a grindrer.
The cluch is removed by removing the water pump layers and simply pulled out. With theshock absorb capabilities gone I used a 3/16 brass rod to cut me some brass drive pins.
5.5 OMC Shock Absorber Removal
red book in the CD section of the LU pages
September 24, 2026 at 7:11 pm #329063Thanks so much for the video link!
I read the section in the Red book, but was surprised that it didn’t say anything other than it doesn’t need service unless it’s broken. I’ve already made a bunch of brass shear pins, and have a variety of welders to make the repair if necessary. I was surprised when I replaced seals on my FD-10 that the factory seals were still in place. I could see over spray of factory paint. Now I took apart this CD-13, and found the same thing!
All of the bushings, gears, etc. look good on both the CD-13 and CD-15. I need to put the clutch dogs side by side to see which is in better shape, but at first glance, there’s minimal wear.
I appreciate everyone helping me learn and showing me where to find parts.
1958 Johnson 5.5 Hp, CD-15 -
