Home Forum Ask A Member New FD21
  • #1910
    wiscoboater
      Hi guys, I just picked up a sweet FD21 with electric start and I’m looking for some part numbers. Carb kit part number, and is there a lower unit seal kit available? or do I have to buy all parts separately? I checked Marinengins.com but I’m only finding individual parts for both the carb and lower.
      Thanks guys,
      Wannabe
      #19295
        The OMC/BRP carb kit P/N is 439071 (Sierra 18-7043) while a Sierra seal kit is 18-2684. I’ve found good deals on Amazon for the seal kits.
        #19297
        retiredoz
          Sierra kit 18-2684 should do the lower carb kit 18-7043, which replaces 382047,382049, 383052, 383067 or 398532, available thru Napa, it says here.
          #19299
            Does one of the BRP kits include a new float?
            #19300
              quote Phil B:
              Yup, the BRP kits are complete!
              #19310
              wiscoboater
                Thanks Guys!
                #19312
                wiscoboater
                  Hey, Couple more questions. This is much newer then what I usually drag home and I have no manual for it. Does anyone have a link to a manual? And is this like my 50’s Johnsons where I have to pull the power head to drop the lower? Also, fuel mix?
                  #19314
                    The official mix on that is 50:1, I still run them a bit richer.
                    You don’t have to pull the powerhead on any of the 18hps to drop the gearcase. Only the 5.5 and 7.5hp OMCS that have the shift connectors under the powerhead. All the others have the shift rod coupler in the leg behind the oval door.
                    #19315
                      Marineengine.com has the parts manual.
                      #19317
                      wiscoboater
                        I’m looking for the service manual. Thanks Chris_P. You guys are the best info on the net. I’m looking for compression info, torque specs and the like. I really need to update my library of reference material to something after 1957. I’m dating myself here…but a 67 is an antique to me! My 57’s and back I call my ancient ones.. NO OFFENCE TO ANYONE!!
