Home › Forum › Ask A Member › New to me to 26
- This topic has 14 replies, 5 voices, and was last updated 5 years, 10 months ago by
lloyd.
April 14, 2020 at 8:11 pm #200023
Bought it on a whim for a ten. It’s froze but I know nothing about These. How do I access pulling the flywheel? In fair shape. All there. Just a couple small dents in tank. Paint is faded. Any advise on where to start? Got it face down with some oil in cylinders. Thanks! Just something different to tinker with when time allows.
April 14, 2020 at 8:26 pm #200025Need to ID your motor try a picture.
April 14, 2020 at 8:29 pm #200026Dang fingers. Johnson Tn 26. My fault for not proofreading my title and post.
April 14, 2020 at 9:27 pm #200030If you are asking how to get the tank off, remove the nut and fork from the primer, Remove the clutch lever. Disconnect the gas line. Unbolt the tank and lift it off.
April 15, 2020 at 8:05 am #200037https://bit.ly/2wqMPTb tn26 covered in the johnson bible
soak cylinders with kerosene or pb blaster etc.… .. for a few days drop the gearcase anyway to change the impeller
http://www.pochefamily.org/outboard/CarbService.html
April 15, 2020 at 8:08 am #200038Was wondering more about the flywheel. Took off the recoil and the gears for the recoil cover up 3 screws which I’m assuming are the holes for a flywheel puller? Just didn’t want to mess with all those little springy wires in not necessary. I hope it frees up. Interested to learn more about it. From pics I notice the ignition is not the same as newer j/e’s.
April 15, 2020 at 8:10 am #200039drop the gearcase (see link) to change impeller anyway
soak the cyl. with kerosene or pb blaster or wd40 for a few days …try again resoak….. try again
April 15, 2020 at 8:18 am #200043drop the gearcase to change the impeller
soak cylinders with kerosene or wd40 or PBBlaster for a few days
see URL on top of the red book picture….to reach the book
April 15, 2020 at 8:40 am #200046Was wondering more about the flywheel. Took off the recoil and the gears for the recoil cover up 3 screws which I’m assuming are the holes for a flywheel puller? Just didn’t want to mess with all those little springy wires in not necessary. I hope it frees up. Interested to learn more about it. From pics I notice the ignition is not the same as newer j/e’s.
Forgive me if I am wrong, but I think that starter pawl plate comes off in one piece by removing the flywheel nut (??)
April 15, 2020 at 9:00 am #200048Thanks Frank and Crosby man will try when I get home from work. The prop turns even with the motor locked up and that worries me.
