Home Forum Ask A Member No wonder i’m having issues with this carb!
  • #327228
    opposedtwin
      This is from a 1967 Evinrude 3hp folder. Crazy! And the needle is stuck solidly in the seat.
      I have never seen a float this out of adjustment.
      I am finding the float pin is stuck too. Will have to clean it well and find a way to sneak it out of there in order to remove the float.
      #327231
        You could be in for more surprises depending on how many other things that person has “repaired” on the motor. Could the float be on up side down?
        #327232
          just send in some wd 40 via the fuel inlet
          #327470
          opposedtwin
            The needle was so badly stuck in the seat that it broke with very little pulling. Time to replace. I have never seen a carb this dried and gunky.
            #327947
            T….in Wisconsin
              It does look like to float is upside down.
