Home Forum Ask A Member Qd10 flywheel
  • #224008
    b-morrison
      is there another flywheel replacement for this motor
      #224015
        According to the Johnson quick reference guide, 580114 is the correct flywheel, and is only used on QD-10 and QD-11. I suppose that is because it has those unobtanium 580040 coils and push-rod points.
        #224018
        labrador-guy
          B & frankr is the 14hp flywheel the same? I have a complete ignition and flywheel for an early 14hp Evinrude. It has coils that work and they are the rare ones. PM me if you are interested.
          dale
          #224055
            Good question on the 14hp. I don’t have that parts book. However, A bit more digging finds that the 12hp Gale 2WB with those coils used a 580088 flywheel, superseded by 580130. 580114 (QD) shows as used only by Johnson, while 580130 was used by Gale and Evinrude, and not Johnson. Confused yet?
            #224056
            labrador-guy
              I was born cofussssed! I know the 12hp gale and the early 14 evinrude used the same power head. Same push rod points vary similar leg and lower unit on the Johnson and Evinrude. My flywheel has a casting number 590571. Casting numbers don’t always jive! Will it work on your Johnson? Might work maybe not?
              dale
