Home Forum Ask A Member Rough estimate for a boat loaded to go out on the water?
  • #8399
    mr-asa
      Howdy folks. Doing a project for a class.
      I was wondering what I could expect a 14 foot fiberglass boat with aluminum prow deck and seats, and a remote steering system that’s been prepped for a day on the water to weigh. I was hoping that everyone here would be able to get me a fairly close estimate, within 25lbs if possible?
      The boat would be a ’56-57 Herter’s Mk III Runabout, claimed weight from the manufacturer was 210lbs, shipping weight was 265lbs
      6 gallons of gas + tank would be 6.75lbs ? One gallon of gas is 6.22lbs, six gallons and associated would be 40lbs
      ’55 25HP Evinrude is (I believe) 85lbs ? EDIT: 118lbs + 9lbs electric start + battery and wiring (15-30lbs for an ATV/Motorcycle battery) –
      Thanks Garry
      Small anchor and rope, 16 lbs or so.
      Things like tools and lifejackets would ride in the bed of the truck, so don’t need to be accounted for.
      Thanks
      #65780
        The weight of the gas would be close to six lbs per US gallon plus the weight of the tank and hose. Oil mixed with the gas would make it slightly heavier.
        #65784
          The 1955 Big Twin model is heavier – 118 pounds. Electric start would add 9 pounds (and the weight of the battery), a long shaft for a 20" transom would add 5 pounds. . . 😀
          #65797
          mr-asa
            quote Mumbles:
            I thought about the oil, but I didn’t think it would change the weight much? For six gallons at 24:1 that’s a quart. Neglected the hose and fittings though.
            quote Garry in Tampa:
            Excellent info, Garry. I’ll edit the first post.
            #65803
            davidk
              As Mumbles is suggesting (I think) the gas + tank would be 36.75 lbs….plus a quart of oil, not the 6.75 lbs you listed. You didn’t edit that which makes me think you’re missing it.
              #65807
                6 gallon tank full is close to #40lbs
                #65920
                mr-asa
                  Long week, sorry for the delay.
                  quote DavidK:
                  quote Dave Bernard:
                  Hey guys, I missed the conversion as I was heading out the door that night. Yes, one gallon of gas weighs 6.216lbs
                  #65939
                    Big question!
                    Life jackets left behind? Account for everything please,
                    #65940
                    1946zephyr
                      If you use a manual start 18, you’ll save a lot of weight
                      #65962
                      mr-asa
                        quote Jeff Register:
                        Big question!
                        They ride in the truck, so are not taken into account for this.
                        I’m trying to get the weight applied to the trailer tires and the hitch. The boat and everything that would ride in it are the only variables I can’t figure out on my own right now.
