Home Forum Ask A Member Sealant or not on old NOS fiber gaskets?
  • #304820
      another practical book to download … included converting oldies to pumps instead of pressure tanks
      changing impeller on some models looks tricky but really not that hard.   visit vintage outboard .com for gaskets
      Johnson Evinrude outboard impellers, seals, lower unit kits, water pump kits, gaskets – VintageOutboard.com
      careful with base gaskets….shapes vary from year to year !!!
      Dropping the Lower Unit on mid 50’s 5.5 and 7.5 Johnsons and Evinrudes
      Cheap Outboards: The Beginner’s Guide to Making an Old Motor Run Forever eBook : Wawrzyniak III, Max: Amazon.ca: Kindle Store
      HOW TO CONVERT 50s motors from two line tanks
      #304821
        I normally do not use a sealer on the cylinder head gasket but yours looks a little sketchy so I would use some on that one.  The exhaust cover gasket should use a sealer.  You should not use a sealer on the intake manifold and reed plate gaskets as you do not want to have any excess sealer gumming up the intake.   BRP gasket sealer or Permatex Aviation sealer #3 are good choices.
        #304823
          http://www.youtube.com/watch?v=SVOedhzPP7M
          #304825
            Well, I do not recommend reusing old gaskets, especially the head gasket.  I would use some light sealer, such as the OMC/merc gasket sealer on most gaskets for sure.  The only exception are the intake gaskets, no sealer should be used on those.  But, I often coat those gaskets with some grease during installation.
            I know that there are many recommendations about not using the light gasket sealer.  On a new engine, with nice/flat machined surfaces, this is fine.  But, we are working on old engines, most of the surfaces are not completely flat.
            #304832
            Stewart Mayer
              Thank you.  If we wanted to0 make our own gaskets, do you happen to know what kind of gasket material to use for head gaskets, and then other gaskets?  We have a laser cutter here, and I could probably scan and trace in the computer the existing gaskets we have, and then quickly laser cut them.  Assuming the laser can cut through the material, they would come out great!
              #304834
              Stewart Mayer
                Thank you everyone for the advice!  I’m loving the manual and links. Regarding the head gaskets, we could make our own by scanning the existing gaskets and cut them out with our CO2 laser cutter, assuming it would cut through the material.  I’d like to try this instead of using the old gaskets we got in.  The originals got torn up while taking the motors apart.
                Can someone tell me what type of gasket material to buy (and maybe where to find it) for different applications such as head gaskets, intake gaskets, base gaskets, etc?
                Also, here is my list of motors.  I found them on marketplace over the past few months and averaged about $50 a piece:
                • 1956 Evinrude 7520, 7.5hp
                • 1954 Evinrude 7516 7.5hp
                • 1958 Evinrude 5516, 5.5hp
                • 1956 Johnson QD-17, 10hp
                • 1950 Johnson QD-11 10hp (this one has a very different carb and is going to be a challenge)
                • 1947 Johnson HD25, 2.5hp
                • and two 1963 McCullogh 7.5hp motors (these are in better shape, but maybe more challenging since parts and information are hard to find)
                #304835
                  Sorry, don’t know much about gasket materials/construction.
